Update #3678.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Add doxygen to the header files in sparc/shared/include directory.
* shared/can/grcan.c, shared/include/debug_defs.h, shared/spw/grspw.c:
Remove use of DEBUG_printf.
* Makefile.am: Add the following new drivers: PCI, b1553BRM,
SpaceWire(GRSPW), CAN (GRCAN,OC_CAN), Raw UART.
* shared/include/apbuart.h, shared/include/apbuart_pci.h,
shared/include/apbuart_rasta.h, shared/include/b1553brm.h,
shared/include/b1553brm_pci.h, shared/include/b1553brm_rasta.h,
shared/include/debug_defs.h, shared/include/grcan.h,
shared/include/grcan_rasta.h, shared/include/grcan_spwrtc.h,
shared/include/grspw.h, shared/include/grspw_pci.h,
shared/include/grspw_rasta.h, shared/include/occan.h,
shared/include/occan_pci.h, shared/include/pci.h: New files.
