Update #4862.
This adds a helper function to read the ECC status for an ECC unit in
SPI-attached NOR memory.
Update #3707.
This resovles gcc warnings by updating to the latest Xilinx NAND
controller driver.
Updates #4662.
This adds helper functions for working with NOR flash connected to the
Xilinx GQSPI controller. The helper functions are based on Xilinx's
QSPIPSU flash interrupt example.
This adds Xilinx's driver for the Xilinx GQSPI controller embedded in
the ZynqMP SoC. Within that device alone, it is possible to access this
peripheral from MicroBlaze, ARMv7, and ARMv8 cores. The imported files
are and should be able to remain unmodified. Import information is kept
in bsps/shared/dev/spi/VERSION.
The shared BSP interrupt controller support code actually implements
parts of the Interrupt Manager.
Update #3706.
Use standard wording in Clock Driver related files.
Update #3706.
The address of the nandpsu peripheral is specific to the ZynqMP SoC and
not relevant to other devices that might have one or more instances of
this peripheral.
This adds Xilinx's driver for the Xilinx NAND controller embedded in the
peripheral from MicroBlaze, ARMv7, and ARMv8 cores. This has been added
to the hardware ZynqMP BSPs since QEMU does not support emulation of
this peripheral. This driver supports polled operation only. The
imported files are and should be able to remain unmodified. Import
information is kept in bsps/shared/dev/nand/VERSION.
This support code is necessary for many Xilinx-provided bare metal device
drivers supported on ARM, AArch64, and MicroBlaze platforms. Support for
all of these architectures is kept under bsps/include due to multiple
architecture variants being supported which requires complex logic in
the build system. The imported files are and should be able to remain
unmodified. Import information is kept in bsps/shared/xil/VERSION.
This enables the tracing of interrupt entry/exit events through an
application configuration option. The interrupt processing can be
viewed with Trace Compass using rtems-record-lttng from the RTEMS Tools.
Update #4769.
Update #4769.
The name handler table was a bit misleading after the last rework.
Rename it to distach table. Update the documentation accordingly.
Update #4769.
This patch changes the license to BSD-2 for all source files where the
copyright is held by Aeroflex Gaisler, Cobham Gaisler, or Gaisler Research.
Some files also includes copyright right statements from OAR and/or
embedded Brains in addition to Gaisler.
Updates #3053.
Update #3707.
Close #4722.
If the bsp is integrated and supported a device tree
blob(dtb) then use dtb instead of using it from
the U-Boot (BSP_START_COPY_FDT_FROM_U_BOOT=False).
Updates #3053.
Make the processor index a parameter.
Make the distributor register block a parameter.
Separate the Interrupt Manager implementation from the generic Arm GICv3
support. Move parts of the Arm GICv3 support into a new header file. This
helps to support systems with a clustered structure in which multiple GICv3
instances are present. For example, two clusters of two Cortex-R52 cores where
each cluster has a dedicated GICv3 instance.
Restrict the affinity set to the set of online processors. Make sure
the affinity set for an interrupt vector contains at least one online
processor.
Update #3269.
Update #3269.
Updates #4625.
Updates #4625.
The <leon.h> include was removed from <bsp.h> in commit
1577a48369fae5e024baa2119b26d25de0f43946.
The memcpy() function may be not loaded at the time bsp_fdt_copy() is
called.
Most BSPs which used the stubbed benachmark timer provide a CPU counter.
All BSPs provide at least a stub CPU counter. Simply use the benchmark
timer implementation using the CPU counter.
Always start the executive in Exception Level 1, Non-Secure mode.
If we boot in EL3 Secure with GICv3 then we have to initialize
the distributor and redistributor to set up G1NS interrupts
early in the boot sequence before stepping down from EL3S to EL1NS.
Now there is no need to distinguish between secure and non-secure
world execution after the primary core boots, so get rid of the
AARCH64_IS_NONSECURE configuration option.
A device tree blob must be aligned on an 8-byte boundary.
The BSPs provide memory for the separate C Program Heap initialization
via _Memory_Get(). Most BSPs provide exactly one memory area. Only two
BSPs provide more than one memory area (arm/altera-cyclone-v and
bsps/powerpc/mpc55xxevb). Only if more than one memory area is
provided, there is a need to use _Heap_Extend(). Provide two
implementations to initialize the separate C Program Heap and let the
BSP select one of the implementations based on the number of provided
memory areas. This gets rid of a dependency on _Heap_Extend(). It
also avoids dead code sections for most BSPs.
Change licence to BSD-2-Clause according to file history.
Update #3053.
The BSPs provide memory for the workspace initialization via
implementations to initialize the workspace handler and let the BSP
select one of the implementations based on the number of provided memory
areas. This gets rid of a dependency on _Heap_Extend(). It also avoids
ARM's GICv2 is configurable and its attributes vary between
implementations including omission of specific interrupts. This allows
BSPs to accomodate those varying implementations with customized
attribute sets.
This adds the SMP function that supports spinup of additional CPU cores
using the ARM standard PSCI inteface. This interface is provided by QEMU
as well as ARM Trusted Firmware running in monitor mode (EL3) on ARMv7 and
AArch64 CPUs. This supports activation va SMC or HVC instructions
depending on BSP configuration.
Close #3250.
Close #4081.
- Trigger on a single character entering the RX FIFO
- Disable the RX timeout
- Send up to a FIFO full of data
Certain files related to the Zynq BSP's I2C driver are useable by the ZynqMP BSP as well.
Moved these files to shared directory in anticipation of I2C support for ZynqMP.
