2021-02-19 | b1553brm.c: Fix Dereference before null check (CID #1399829) | Ryan Long | 1 | -2/+5 | |
CID 1399829: Dereference before null check in brm_control(). Closes #4250 | |||||
2020-12-14 | bsps: Replace non-ASCII bullet points | Christian Mauderer | 2 | -6/+6 | |
2020-11-09 | Add networking support for griscv bsp | Jiri Gaisler | 1 | -12/+12 | |
* Only GRETH device supported for now * Fix endian problem in GRETH driver * Remove SPARC assembly from greth.c * Builds with both autoconf and waf | |||||
2020-10-16 | grlib: Add ambapp_common_info to derived types | Sebastian Huber | 11 | -27/+27 | |
This avoids a cast in DEV_TO_COMMON(). | |||||
2020-10-10 | grlib: Add and use irqmp_has_timestamp() | Sebastian Huber | 1 | -1/+1 | |
Replace leon3_irqmp_has_timestamp() with irqmp_has_timestamp() and move it to grlib.h. Close #4128. | |||||
2020-02-20 | drvmgr: Fix determination of prefix in grlib uart driver | Dennis Pfau | 1 | -1/+1 | |
drvmgr_get_dev_prefix returns 0 if a prefix was found. Therefore the if condition needs to check for 0, i.e. DRVMGR_OK. | |||||
2019-12-11 | clock: Simplify driver initialization | Sebastian Huber | 1 | -11/+2 | |
Use a system initialization handler instead of a legacy IO driver. Update #3834. | |||||
2019-05-27 | bsps: Fix warnings in greth | Sebastian Huber | 1 | -3/+3 | |
2019-01-22 | grlib: make memory coherency cpu-independent | Jiri Gaisler | 1 | -1/+1 | |
Update #3678. | |||||
2019-01-22 | grlib: use cpu-independent routines for uncached access | Jiri Gaisler | 6 | -71/+10 | |
2019-01-22 | grlib: use rtems_interrupt_handler_install() | Jiri Gaisler | 4 | -8/+15 | |
2019-01-22 | grlib: make apbuart driver independent of bsp | Jiri Gaisler | 1 | -16/+16 | |
2019-01-22 | grlib: Move source files | Sebastian Huber | 66 | -0/+49217 | |
Update #3678. |
