path: root/bsps/shared/grlib/pci (follow)
* gr_tmtc_1553.c: Unchecked return value from library (CID #1399785)Ryan Long2021-03-051-1/+3
| | | | | | CID 1399785: Unchecked return value from library in gr_tmtc_1553_init1(). Closes #4289
* gr_701.c: Unchecked return value from library (CID #1399783)Ryan Long2021-03-051-1/+3
| | | | | | CID 1399783: Unchecked return value from library in gr701_init1(). Closes #4288
* gr_rasta_adcdac.c: Fix Unchecked return value from library (CID #1399780)Ryan Long2021-03-051-1/+3
| | | | | | CID 1399780: Unchecked return value from library in gr_rasta_adcdac_init1(). Closes #4287
* gr_rasta_tmtc.c: Fix Unchecked return value from library (CID #1399771)Ryan Long2021-03-051-1/+3
| | | | | | CID 1399771: Unchecked return value from library in gr_rasta_tmtc_init1(). Closes #4286
* gr_rasta_io.c: Fix Unchecked return value from library (CID #1399763)Ryan Long2021-03-051-1/+3
| | | | | | CID 1399763: Unchecked return value from library in gr_rasta_io_init1(). Closes #4284
* gr_rasta_spw_router.c: Fix Unchecked return value from library (CID #1399760)Ryan Long2021-03-051-1/+3
| | | | | | CID 1399760: Unchecked return value from library in gr_rasta_spw_router_init1(). Closes #4283
* grlib: Add ambapp_common_info to derived typesSebastian Huber2020-10-163-4/+4
| | | | This avoids a cast in DEV_TO_COMMON().
* grlib: use cpu-independent routines for uncached accessJiri Gaisler2019-01-221-1/+1
| | | | Update #3678.
* grlib: Move source filesSebastian Huber2019-01-2210-0/+8696
Update #3678.
