* | leon,grcan: split out GRCAN non-FD specific support in separate file | Daniel Hellstrom | 2021-03-11 | 2 | -405/+435 |
| | | | | Close #4324. | ||||
* | leon,grcanfd: split out GRCANFD specific support in separate file | Daniel Hellstrom | 2021-03-11 | 3 | -627/+686 |
| | | | | Update #4324. | ||||
* | leon,grcan: added support for GRCANFD | Daniel Hellstrom | 2021-03-11 | 1 | -16/+568 |
| | | | | | | | | | | | | | The new GRCAN_FD IP supports CAN FD standard and is mostly backwards compatible with GRCAN SW interface. The GRCAN driver have been extended to support the GRCANFD IP using the same driver. Additional functions have been added that uses a new CAN FD frame format and read/write/baud-rate functions that supports both GRCANFD and GRCAN. To keep the SW API fully backwards compatible with GRCAN, the old functions remain. Update #4324. | ||||
* | leon,occan: use common CAN baud-rate calculation routine | Daniel Hellstrom | 2021-03-11 | 1 | -110/+41 |
| | | | | Close #4323. | ||||
* | leon,grcan: use common CAN baud-rate calculation routine | Daniel Hellstrom | 2021-03-11 | 1 | -114/+20 |
| | | | | Update #4323. | ||||
* | leon,can: introduce common CAN baud-rate calculation function | Daniel Hellstrom | 2021-03-11 | 1 | -0/+144 |
| | | | | | | | Reimplemented the baud-rate algorithm from scratch to cope with GRCAN, GRCANFD and OC_CAN devices. Update #4323. | ||||
* | grcan.c: Fix Unused value (CID #1437613) | Ryan Long | 2021-03-05 | 1 | -1/+1 |
| | | | | | | | CID 1437613: Unused value in grcan_set_filter(). This fix was recommended by Daniel Hellstrom (daniel@gaisler.com). Closes #4301 | ||||
* | satcan.c: Fix Unsigned compared against 0 (CID #1399768) | Ryan Long | 2021-03-05 | 1 | -12/+4 |
| | | | | | | CID 1399768: Unsigned compared against 0 in satcan_ioctl(). Closes #4294 | ||||
* | bsps: Replace non-ASCII bullet points | Christian Mauderer | 2020-12-14 | 1 | -2/+2 |
* | grlib: Add ambapp_common_info to derived types | Sebastian Huber | 2020-10-16 | 1 | -1/+1 |
| | | | | This avoids a cast in DEV_TO_COMMON(). | ||||
* | grlib: use cpu-independent routines for uncached access | Jiri Gaisler | 2019-01-22 | 1 | -24/+3 |
| | | | | Update #3678. | ||||
* | grlib: use rtems_interrupt_handler_install() | Jiri Gaisler | 2019-01-22 | 1 | -2/+4 |
* | grlib: Move source files | Sebastian Huber | 2019-01-22 | 4 | -0/+4862 |
Update #3678. |
