* | leon,gr1553b: Only align allocated memory. Verify alignment of memory. | Arvid Bjorkengren | 2021-03-11 | 3 | -83/+147 |
* | leon,gr1553b: set codec version | Arvid Bjorkengren | 2021-03-11 | 1 | -0/+4 |
| | | | | | This is enables the updated codec for GR740 and is backwards compatible with all other versions of the IP. | ||||
* | leon,gr1553rt: Fixed spinlock unlock | Arvid Bjorkengren | 2021-03-11 | 1 | -1/+1 |
* | leon,gr1553rt: Fixed memory leak | Arvid Bjorkengren | 2021-03-11 | 1 | -5/+11 |
* | b1553brm.c: Fix Unsigned compared against 0 (CID #1399773) | Ryan Long | 2021-03-05 | 1 | -1/+1 |
| | | | | | | CID 1399773: Unsigned compared against 0 in brm_write(). Closes #4295 | ||||
* | b1553rt.c: Fix Deference before null check (CID #1399830) | Ryan Long | 2021-02-19 | 1 | -1/+3 |
| | | | | | | CID 1399830: Dereference before null check in rt_control(). Closes #4251 | ||||
* | b1553brm.c: Fix Dereference before null check (CID #1399829) | Ryan Long | 2021-02-19 | 1 | -2/+5 |
| | | | | | | CID 1399829: Dereference before null check in brm_control(). Closes #4250 | ||||
* | grlib: use cpu-independent routines for uncached access | Jiri Gaisler | 2019-01-22 | 2 | -19/+2 |
| | | | | Update #3678. | ||||
* | grlib: Move source files | Sebastian Huber | 2019-01-22 | 6 | -0/+6122 |
Update #3678. |
