Update #3285.
Move the gdb stub from the i386 UART code to use the libchip drivers.
Use any ports discovered during the probes.
Add gdb control to the boot command line.
Change the device naming to the full device path, not a partial path.
For example /dev/com1.
and bsp_com_outch()
This patch adds the "--printk=" boot command line argument to specify
the printk() device. It also enhances the "--console=" boot command
line argument to match any device configured in the console device
table. The arguments are parsed as early as possible so they take
effect early. Currently, this is immediately after PCI initialization.
* console_private.h: Removed Console_Port_Minor declaration.
* console.c: Define console_initialized as static.
PR 1917/bsps
* console.c: Modifications to add dynamic tables for libchip serial
drivers.
* console_control.c, console_private.h, console_read.c,
console_select.c, console_write.c: New files.
