Update #3285.
Update #3132.
Update #2133.
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
Move the gdb stub from the i386 UART code to use the libchip drivers.
Use any ports discovered during the probes.
Add gdb control to the boot command line.
Change the device naming to the full device path, not a partial path.
For example /dev/com1.
This patch adds the "--printk=" boot command line argument to specify
the printk() device. It also enhances the "--console=" boot command
line argument to match any device configured in the console device
table. The arguments are parsed as early as possible so they take
effect early. Currently, this is immediately after PCI initialization.
Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC
into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to
figure out the code position given a fatal source and code.
* console.c: Added a some error checks and fixed a error message.
* console_private.h: Removed Console_Port_Minor declaration.
* console.c: Define console_initialized as static.
* console.c: Include <rtems/error.h> for rtems_panic().
* console.c: RTEMS_DEBUG is a define, not a variable.
PR 1917/bsps
* console.c: Modifications to add dynamic tables for libchip serial
drivers.
* console_control.c, console_private.h, console_read.c,
console_select.c, console_write.c: New files.
* console.c: Make device file optional.
* console.c: Register also normal device file of the console device.
Call initialization before the device file registration.
* console.c: Flow control is optional.
* console.c: Fix tabs and allow the BSP to override the default baud
rate.
PR 577/bsps
* console.c: Make the previously committed patch for this PR compile.
PR 577/bsps
* console.c: The console_close() method currently calls StopRemoteTx()
on all invocations. It should should be ok for last close only but
not for any others. If you open a port multiple times, you only want
to call StopRemoteTx() only as part of the last close.
PR 501/rtems_misc
* console.c: console_open disables ICANON on non-console port, which
should be ok for the first open but not for subsequent ones. If you
open one serial port, you will configure it, when you reopen it you
will lost the ICANON parameters if you had put it. Should be done by
console only at first open.
* bootcard.c, bspclean.c, clockdrv_shell.c, console-polled.c,
console.c, ide_ctrl.c, main.c, sbrk.c, setvec.c, tod.c, tod.h,
include/coverhd.h: URL for license changed.
* console-polled.c, console.c: Fixed typo.
for RTEMS.
Modified open so it uses a local variable rather than modifying a parameter.
