2018-04-04 | bsps: Move libchip to bsps | Sebastian Huber | 1 | -0/+0 | |
This patch is a part of the BSP source reorganization. Update #3285. | |||||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -4/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
1998-07-09 | Added information to README.mc68681. | Joel Sherrill | 1 | -0/+17 | |
Created the basic README and the README.z85c30. |
