Make the GIC interrupt controller support a subgroup of the generic interrupt
controller support.
In addtion to 1023, the GICC_IAR register may return 1022 as a special value.
Simply check for a valid interrupt vector for the dispatching.
Check the GICC_IAR again after the dispatch to quickly process a next interrupt
without having to go through the interrupt prologue and epiloge.
This fixes commit b678a199e499b6c3f0b453393434aefaee180423 for SMP
configurations.
Move declarations of bsp_interrupt_get_affinity() and
bsp_interrupt_set_affinity() to <bsp/irq-generic.h>. Canonicalize the
<bsp/irq.h> includes.
Implement bsp_interrupt_get_affinity() and bsp_interrupt_set_affinity() only if
needed (usually RTEMS_SMP).
Provide stub implementations for i386 to fix build errors.
Provide arm_gic_irq_processor_count() only in SMP configurations.
brains GmbH.
Updates #3053.
Updates #4625.
ARM's GICv2 is configurable and its attributes vary between
implementations including omission of specific interrupts. This allows
BSPs to accomodate those varying implementations with customized
attribute sets.
Do not return a status code in bsp_interrupt_facility_initialize() since this
leads to unreachable code in bsp_interrupt_initialize(). Use RTEMS_DEBUG
assertions in bsp_interrupt_facility_initialize() if necessary.
Update #3269.
Return a status code for bsp_interrupt_set_affinity().
Update #3269.
Return a status code for bsp_interrupt_get_affinity().
Update #3269.
Return a status code for bsp_interrupt_vector_disable().
Update #3269.
Return a status code for bsp_interrupt_vector_enable().
Update #3269.
Add a default implementation which just returns RTEMS_UNSATISFIED.
Update #3269.
Add a default implementation which clears the attributes to zero and
just returns RTEMS_SUCCESSFUL for valid parameters.
Update #3269.
Add rtems_interrupt_raise_on() and rtems_interrupt_clear().
Add a default implementation which just returns RTEMS_UNSATISFIED for
valid parameters.
Update #3269.
valid parameters.
Update #3269.
This avoids a function call overhead in the interrupt dispatching.
Update #4202.
Avoid one level of indirection.
Update #4202.
Update #4202.
Remove the target filter for software-generated interrupts since this
feature is not supported by the affinity routing in GICv3.
Update #4202.
Use the targets parameter to determine the targets of the SGI. Change
targets parameter type to 32-bit to ease the parameter passing. GICv3
supports up to 16 targets.
Update #4202.
This moves the ARM GICv2 driver to bsps/shared to be usable by AArch64
code.
This breaks out AArch32-specific code so that the shared GICv3 code can
be reused by other architectures.
At least on GICv1 the interrupts 0 up to including 31 are so called
Peripheral Private Interrupts (PPIs). We have to initialize the
priority of the PPIs on secondary processors.
This adds support for the GICv3 interrupt controller along with the
redistributor to control SGIs and PPIs which wasn't present in GICv2
implementations. GICv3 implementations only optionally support
memory-mapped GICC interface interaction and require system register
access be implemented, so the GICC interface is accessed only
through system registers.
The following variants
* GICv1 with Security Extensions,
* GICv2 without Security Extensions, or
* within Secure processor mode
have the ability to assign group 0 or 1 to individual interrupts. Group
0 interrupts can be configured to raise an FIQ exception. This enables
the use of NMIs with respect to RTEMS.
BSPs can enable this feature with the BSP_ARM_GIC_ENABLE_FIQ_FOR_GROUP_0
define. Use arm_gic_irq_set_group() to change the group of an
interrupt (default group is 1, if BSP_ARM_GIC_ENABLE_FIQ_FOR_GROUP_0 is
defined).
Update #3285.
Close #3071.
Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
to not return a status code. Add bsp_interrupt_assert() and use it to
validate the vector number in the vector enable/disable implementations.
Update #2554.
Some GIC implementations do not have the complete range of priorities.
The upper bits are RAZ/WI in this case.
