If we interrupt a thread dispatch critical section (thread dispatch
disable level != ISR nest level), then we should not do the fast idle
mode since this may delay an ongoing system call forever.
CLOCK_DRIVER_ISRS_PER_TICK is the configuration define,
CLOCK_DRIVER_ISRS_PER_TICK_VALUE is the actual value of ISRS per clock
tick, therefore use this one to reset the Clock_driver_isrs after each
tick.
Use a specific test to enable the fast idle mode instead of using the
rtems_configuration_is_smp_enabled() workaround.
Update #3876.
Use a system initialization handler instead of a legacy IO driver.
Update #3834.
Rename _SMP_Get_processor_count() in _SMP_Get_processor_maximum() to be
in line with the API level rtems_scheduler_get_processor_maximum().
Update #3732.
replace.
searching and sorting.
Update #3706.
Update #3598.
The aim of this clock driver hook was to stop clock tick interrupts at
some late point in the exit() procedure.
The use of atexit() pulls in malloc() which pulls in errno. It is
incompatible with the intention of the
CONFIGURE_DISABLE_NEWLIB_REENTRANCY configuration option.
The exit() function must be called from thread context, so accompanied
clock tick interrupts should cause no harm. On the contrary, someone
may assume a normal operating system operation, e.g. working timeouts.
Remove the Clock_driver_support_shutdown_hardware() clock driver hook.
Close #3436.
Update #3285.
