path: root/bsps/sh (unfollow)
2020-04-06tests: Exclude record02 for some BSPsSebastian Huber6-0/+6
Update #3938.
2020-02-12score: Statically allocate idle/MPCI stacksSebastian Huber4-0/+16
Place idle and MPCI stacks into extra linker sections. This can be optionally used by applications to control the placement of the stacks. Update #3835.
2020-02-04bsps: Add RamEnd to linker command filesSebastian Huber8-0/+8
Update #3838.
2019-12-11clock: Simplify driver initializationSebastian Huber3-37/+3
Use a system initialization handler instead of a legacy IO driver. Update #3834.
2019-12-11clock: Remove Clock_exit() from APISebastian Huber3-1/+5
This function is no longer supported by the standard clock driver implementation (clockimpl.h). Update #3436.
2019-07-05bsps: Regenerate headers.amSebastian Huber4-0/+13
Update #3269.
2019-05-16bsps: Always build generic interrupt supportSebastian Huber4-0/+4
This makes it possible to write tests for the generic interrupt controller support. Update #3269.
2019-03-14Remove superfluous <rtems/system.h> includesSebastian Huber5-5/+0
2019-03-08bsps: Adjust bsp.h Doxygen groupsSebastian Huber4-0/+81
Update #3706.
2019-03-04bsps: Adjust architecture Doxygen groupsSebastian Huber1-0/+7
- Use CamelCase as it is not used in our C code. Enables simple search and replace. - Prefix with "RTEMS" to aid deployment and integration. It aids searching and sorting. Update #3706.
2018-11-12sh: Remove use of proc_ptrSebastian Huber7-16/+7
Update #3585.
2018-11-08score: Rename interrupt stack symbolsSebastian Huber6-6/+6
Rename * _Configuration_Interrupt_stack_area_begin in _ISR_Stack_area_begin, * _Configuration_Interrupt_stack_area_end in _ISR_Stack_area_end, and * _Configuration_Interrupt_stack_size in _ISR_Stack_size. Move definitions to <rtems/score/isr.h>. The new names are considerable shorter and in the right namespace. Update #3459.
2018-06-27Rework initialization and interrupt stack supportSebastian Huber23-191/+10
Statically initialize the interrupt stack area (_Configuration_Interrupt_stack_area_begin, _Configuration_Interrupt_stack_area_end, and _Configuration_Interrupt_stack_size) via <rtems/confdefs.h>. Place the interrupt stack area in a special section ".rtemsstack.interrupt". Let BSPs define the optimal placement of this section in their linker command files (e.g. in a fast on-chip memory). This change makes makes the CPU_HAS_SOFTWARE_INTERRUPT_STACK and CPU_HAS_HARDWARE_INTERRUPT_STACK CPU port defines superfluous, since the low level initialization code has all information available via global symbols. This change makes the CPU_ALLOCATE_INTERRUPT_STACK CPU port define superfluous, since the interrupt stacks are allocated by confdefs.h for all architectures. There is no need for BSP-specific linker command file magic (except the section placement), see previous ARM linker command file as a bad example. Remove _CPU_Install_interrupt_stack(). Initialize the hardware interrupt stack in _CPU_Initialize() if necessary (e.g. m68k_install_interrupt_stack()). The optional _CPU_Interrupt_stack_setup() is still useful to customize the registration of the interrupt stack area in the per-CPU information. The initialization stack can reuse the interrupt stack, since * interrupts are disabled during the sequential system initialization, and * the boot_card() function does not return. This stack resuse saves memory. Changes per architecture: arm: * Mostly replace the linker symbol based configuration of stacks with the standard <rtems/confdefs.h> configuration via CONFIGURE_INTERRUPT_STACK_SIZE. The size of the FIQ, ABT and UND mode stack is still defined via linker symbols. These modes are rarely used in applications and the default values provided by the BSP should be sufficient in most cases. * Remove the bsp_processor_count linker symbol hack used for the SMP support. This is possible since the interrupt stack area is now allocated by the linker and not allocated from the heap. This makes some configure.ac stuff obsolete. Remove the now superfluous BSP variants altcycv_devkit_smp and realview_pbx_a9_qemu_smp. bfin: * Remove unused magic linker command file allocation of initialization stack. Maybe a previous linker command file copy and paste problem? In the start.S the initialization stack is set to a hard coded value. lm32, m32c, mips, nios2, riscv, sh, v850: * Remove magic linker command file allocation of initialization stack. Reuse interrupt stack for initialization stack. m68k: * Remove magic linker command file allocation of initialization stack. Reuse interrupt stack for initialization stack. powerpc: * Remove magic linker command file allocation of initialization stack. Reuse interrupt stack for initialization stack. * Used dedicated memory region (REGION_RTEMSSTACK) for the interrupt stack on BSPs using the shared linkcmds.base (replacement for REGION_RWEXTRA). sparc: * Remove the hard coded initialization stack. Use the interrupt stack for the initialization stack on the boot processor. This saves 16KiB of RAM. Update #3459.
2018-06-27bsps: Support .rtemsstack.* linker input sectionsSebastian Huber8-7/+34
Use a dedicated memory region or place it between the BSS and workspace. Update #3459.
2018-06-11tools: Remove shgenSebastian Huber6-13/+83
All tools should be removed from the RTEMS source repository at some point in time. Tools with a BSD-style license will be moved to the RTEMS tools repository. Unfortunately, the shgen tool is GPL licensed. Remove all uses of this tool from the code base. Replace generated files with stub functions. If users of this BSP still exist, they can reimplement the functionality using a BSD-style license. Close #3443.
2018-04-26bsps: Move documentation, etc. files to bspsSebastian Huber5-0/+390
This patch is a part of the BSP source reorganization. Update #3285.
2018-04-25bsp/gensh4: Move hw_init.c to bspsSebastian Huber1-0/+283
2018-04-23bsps/sh: Move console.c to bspsSebastian Huber1-0/+123
2018-04-23bsps/sh: Move setvec.c to bspsSebastian Huber1-0/+55
2018-04-23bsps/sh: Move bsphwinit.c to bspsSebastian Huber1-0/+18
2018-04-23bsps: Move make/custom/* files to bspsSebastian Huber13-0/+223
Adjust various build files. Remove automatic generation of the c/src/lib/libbsp/*/acinclude.m4 files from bootstrap script. This patch is a part of the BSP source reorganization. Update #3285.
2018-04-20bsps: Move benchmark timer to bspsSebastian Huber3-0/+655
2018-04-20bsps: Move startup files to bspsSebastian Huber23-0/+3698
Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285.
2018-04-20bsps: Move start files to bspsSebastian Huber6-0/+941
2018-04-20bsps: Move console drivers to bspsSebastian Huber9-0/+2978
2018-04-20bsps: Move clock drivers to bspsSebastian Huber4-0/+844
2018-03-16bsps/sh/gensh1/include/bsp.h: Fix redefined warningJoel Sherrill1-13/+0
2018-03-12misc sh: Remove includes of rtems/score/types.hJoel Sherrill3-6/+0
2018-01-25Remove make preinstallChris Johns32-0/+4263
