line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
* clock/ckinit.c, include/io_types.h, include/iosh7045.h,
include/ispsh7045.h, include/sci.h, include/sci_termios.h,
include/sh7_pfc.h, include/sh7_sci.h, sci/sci.c, sci/sci_termios.c,
score/cpu_asm.c, score/ispsh7045.c, timer/timer.c: URL for license
changed.
John Mills <jmills@tga.com>.
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
