path: root/bsps/riscv/include (follow)
* bsps: Adjust shared Doxygen groupsSebastian Huber2019-03-081-2/+2
| | | | Update #3706.
* bsps/riscv: Update linker-symbols.hSebastian Huber2018-07-251-15/+16
| | | | Update #3433.
* riscv: Rework exception handlingSebastian Huber2018-07-251-4/+0
| | | | | | | | | | | Remove _CPU_ISR_install_raw_handler() and _CPU_ISR_install_vector() functions. Applications can install an exception handler via the fatal error handler to handle synchronous exceptions. Handle interrupt exceptions via _RISCV_Interrupt_dispatch() which must be provided by the BSP. Update #3433.
* bsps: Remove superfluous bsp_processor_countSebastian Huber2018-06-191-2/+0
| | | | | | This is unused copy and paste stuff. Update #3459.
* Remove make preinstallChris Johns2018-01-251-0/+81
