brains GmbH.
Updates #3053.
Updates #4625.
Updates #4625.
Update #3285.
Due to a new rtems_panic() implementation, it is possible to replace the
PowerPC-specific BSP_panic() with rtems_panic(). Remove BSP_panic()
implementations.
Close #3245.
Switched to using the PPC403 clock driver. Added support for the MMU but
didn't enable it by default. Made some functions static to avoid compiler
warnings. Added a README.
This commit covers at least PR2020, 2022, and 2023. This
patch adds all of the code for both BSPs, modifications
to libcpu/powerpc for the ppc440, and some updates to the
BSPs from follow up review and testing.
These BSPs should be good baselines for future development.
The configurations used by Ric are custom and have a non-standard
NIC. They also do not have a UART. Thus the current console
driver just prints to a RAM buffer.
The NIC and UART support are left for future work. When the UART
support is added, moving the existing "to RAM" console driver to
a shared location is likely desirable because boards with no debug
UART port are commonly deployed. This would let printk() go to RAM.
PR 1929/bsps
* irq/irq_init.c: Fixed warning.
* irq/irq_init.c, include/bsp.h:
define BSP_PPC403_CLOCK_HOOK_EXCEPTION
so that we hook the timer exception rather than going
through the interrupt dispatcher.
* Makefile.am, preinstall.am, irq/irq_init.c:
Use low-level exception handling support from
new-exceptions/bspsupport.
* irq/irq_init.c:
renamed ASM_BOOKE_PIT_VECTOR to ASM_BOOKE_DEC_VECTOR
to be closer to 'official' nomenclature.
* ep1a/irq/irq.c, gen5200/irq/irq.c, gen83xx/irq/irq_init.c,
mbx8xx/irq/irq.c, mpc8260ads/irq/irq.c, mvme5500/irq/irq.c,
psim/irq/no_pic.c, score603e/irq/irq.c, shared/irq/irq_supp.h,
shared/irq/openpic_i8259_irq.c, virtex/irq/irq_init.c:
let C_dispatch_irq_handler() return zero to indicate to
low-level exception handling code that the exception
was handled (not used yet).
* virtex/irq/irq_init.c: use new ASM_xxx_VECTOR names.
PR 1257/bsps
* irq/irq_init.c: Code outside of cpukit should use the public API for
rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the
public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
exception handling
