Update #3866.
This fixes an issue with the latest tool chain which adds the default
linker script in the endfile specification.
Update #3250.
Remove superflous __atexit stuff in start.o. It is no longer required
by GCC and may cause linker problems.
See GCC commit:
commit 362c63a5e8b5aacfff3e5af0911e42ba7c775042
Author: Geoff Keating <geoffk@cygnus.com>
Date: Fri Apr 14 23:16:25 2000 +0000
Update #3838.
Close #3339.
Use a system initialization handler instead of a legacy IO driver.
Update #3834.
This function is no longer supported by the standard clock driver
implementation (clockimpl.h).
Update #3436.
controller support.
Update #3269.
Update #3706.
Updates #3687
The size of the sample executables without this option were:
116512 1340 15400 133252 20884 ./base_sp.exe
246172 2328 18324 266824 41248 ./capture.exe
319368 3520 16496 339384 52db8 ./cdtest.exe
1077464 22428 23284 1123176 112368 ./cxx_iostream.exe
640632 4916 28408 673956 a48a4 ./fileio.exe
148844 1692 15572 166108 288dc ./hello.exe
328648 6252 22408 357308 573bc ./loopback.exe
95828 1196 12224 109248 1aac0 ./minimum.exe
145576 1872 15528 162976 27ca0 ./nsecs.exe
194932 2100 16172 213204 340d4 ./paranoia.exe
537060 12460 45124 594644 912d4 ./pppd.exe
119620 1380 15464 136464 21510 ./ticker.exe
119388 1324 19300 140012 222ec ./unlimited.exe
The size of the sample executables with this option were:
235000 2336 16628 253964 3e00c ./cxx_iostream.exe
627252 4892 28108 660252 a131c ./fileio.exe
137648 1676 15528 154852 25ce4 ./hello.exe
308616 6236 22336 337188 52524 ./loopback.exe
89564 1180 12144 102888 191e8 ./minimum.exe
137184 1856 15432 154472 25b68 ./nsecs.exe
184264 2084 16144 202492 316fc ./paranoia.exe
520768 12440 45020 578228 8d2b4 ./pppd.exe
113260 1364 15356 129980 1fbbc ./ticker.exe
117236 1308 19272 137816 21a58 ./unlimited.exe
110584 1324 15308 127216 1f0f0 ./base_sp.exe
229172 2316 18288 249776 3cfb0 ./capture.exe
233980 2320 16436 252736 3db40 ./cdtest.exe
Closes #2563
Move start.o to separate file.
Update #3459.
Rename
* _Configuration_Interrupt_stack_area_begin in _ISR_Stack_area_begin,
* _Configuration_Interrupt_stack_area_end in _ISR_Stack_area_end, and
* _Configuration_Interrupt_stack_size in _ISR_Stack_size.
Move definitions to <rtems/score/isr.h>. The new names are considerable
shorter and in the right namespace.
Update #3459.
Statically initialize the interrupt stack area
(_Configuration_Interrupt_stack_area_begin,
_Configuration_Interrupt_stack_area_end, and
_Configuration_Interrupt_stack_size) via <rtems/confdefs.h>. Place the
interrupt stack area in a special section ".rtemsstack.interrupt". Let
BSPs define the optimal placement of this section in their linker
command files (e.g. in a fast on-chip memory).
This change makes makes the CPU_HAS_SOFTWARE_INTERRUPT_STACK and
CPU_HAS_HARDWARE_INTERRUPT_STACK CPU port defines superfluous, since the
low level initialization code has all information available via global
symbols.
This change makes the CPU_ALLOCATE_INTERRUPT_STACK CPU port define
superfluous, since the interrupt stacks are allocated by confdefs.h for
all architectures. There is no need for BSP-specific linker command
file magic (except the section placement), see previous ARM linker
command file as a bad example.
Remove _CPU_Install_interrupt_stack(). Initialize the hardware
interrupt stack in _CPU_Initialize() if necessary (e.g.
m68k_install_interrupt_stack()).
The optional _CPU_Interrupt_stack_setup() is still useful to customize
the registration of the interrupt stack area in the per-CPU information.
The initialization stack can reuse the interrupt stack, since
* interrupts are disabled during the sequential system initialization,
and
* the boot_card() function does not return.
This stack resuse saves memory.
Changes per architecture:
arm:
* Mostly replace the linker symbol based configuration of stacks with
the standard <rtems/confdefs.h> configuration via
CONFIGURE_INTERRUPT_STACK_SIZE. The size of the FIQ, ABT and UND
mode stack is still defined via linker symbols. These modes are
rarely used in applications and the default values provided by the
BSP should be sufficient in most cases.
* Remove the bsp_processor_count linker symbol hack used for the SMP
support. This is possible since the interrupt stack area is now
allocated by the linker and not allocated from the heap. This makes
some configure.ac stuff obsolete. Remove the now superfluous BSP
variants altcycv_devkit_smp and realview_pbx_a9_qemu_smp.
bfin:
* Remove unused magic linker command file allocation of initialization
stack. Maybe a previous linker command file copy and paste problem?
In the start.S the initialization stack is set to a hard coded value.
lm32, m32c, mips, nios2, riscv, sh, v850:
* Remove magic linker command file allocation of initialization stack.
Reuse interrupt stack for initialization stack.
m68k:
powerpc:
* Used dedicated memory region (REGION_RTEMSSTACK) for the interrupt
stack on BSPs using the shared linkcmds.base (replacement for
REGION_RWEXTRA).
sparc:
* Remove the hard coded initialization stack. Use the interrupt stack
for the initialization stack on the boot processor. This saves
16KiB of RAM.
Update #3459.
Use a dedicated memory region or place it between the BSS and workspace.
Update #3459.
Add rtems_counter_frequency() API function. Use it to initialize the
counter value converter via the new system initialization step
(RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation
and the counter converter. It avoids an unnecessary pull in of the
64-bit integer division from libgcc.
Update #3456.
The mpc555 define is provided via <bspopts.h>. It must not be used in
cpukit header files.
Update #3425.
Updates #3425.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Use only one timer driver variant based on the standard PowerPC time
base.
Update #3285.
Update #3285.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
