2023-05-20 | Update company name | Sebastian Huber | 10 | -10/+10 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2023-04-11 | bsps/powerpc: Fix warnings with PPC_SPECIAL_PURPOSE_REGISTER | Chris Johns | 1 | -10/+15 | |
2022-09-08 | powerpc: Add support for VRSAVE | Sebastian Huber | 1 | -5/+184 | |
The VRSAVE feature of the Altivec unit can be used to reduce the amount of Altivec registers which need to be saved/restored during interrupt processing and context switches. In order to use the VRSAVE optimization a corresponding multilib (-mvrsave) is required, see GCC configuration. The -mvrsave option must be added to the ABI_FLAGS of the BSP. Currently only the -mcpu=e6500 based QorIQ BSP support this optimization. Update #4712. | |||||
2022-07-12 | bsps/powerpc/shared: Change license to BSD-2 | Joel Sherrill | 6 | -18/+132 | |
Updates #3053. | |||||
2022-03-10 | bsps/powerpc/: Scripted embedded brains header file clean up | Joel Sherrill | 6 | -36/+2 | |
Updates #4625. | |||||
2020-07-05 | bsps/powerpc: Fix inline assembly | Sebastian Huber | 1 | -24/+21 | |
GCC 10 no longer passes -many to the assembler. This enables more checks in the assembler. | |||||
2019-03-14 | Remove superfluous <rtems/system.h> includes | Sebastian Huber | 1 | -1/+0 | |
2019-03-08 | bsps: Adjust shared Doxygen groups | Sebastian Huber | 1 | -1/+1 | |
Update #3706. | |||||
2019-01-25 | bsps/powerpc: Fix warnings | Sebastian Huber | 1 | -2/+2 | |
2018-12-04 | Spelling and grammar fixes in source code comments (GCI 2018) | Marçal Comajoan Cara | 1 | -1/+1 | |
2018-11-09 | Include missing <rtems/score/thread.h> | Sebastian Huber | 1 | -0/+1 | |
Update #3598. | |||||
2018-09-06 | bsps/powerpc: Simplify ppc_exc_initialize() | Sebastian Huber | 1 | -2/+1 | |
Remove parameters from ppc_exc_initialize() since all BSPs passed the same values. Update #3459. | |||||
2018-04-24 | bsps: Move ppc-exc-handler-table.c to bsps | Sebastian Huber | 1 | -0/+67 | |
This patch is a part of the BSP source reorganization. Update #3285. | |||||
2018-03-19 | bsps/powerpc: Move exceptions support to bsps | Sebastian Huber | 15 | -0/+3892 | |
