2018-06-27 | bsps: Support .rtemsstack.* linker input sections | Sebastian Huber | 1 | -1/+1 | |
Use a dedicated memory region or place it between the BSS and workspace. Update #3459. | |||||
2018-04-20 | bsps: Move startup files to bsps | Sebastian Huber | 1 | -0/+0 | |
Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285. | |||||
2017-12-20 | gen5200, gen83xx, gen83x, mpc55xxevb, psim, qoriq, t32mppc, tqm8xx, virtex: ↵ | Joel Sherrill | 1 | -0/+2 | |
Simplify bsp_specs These BSPs all use shared/startup/linkcmds.base and thus needed to be modified at the same time. Variations in the arguments were reflected into the BSP specific portions of the linkcmds. Updates #3520. | |||||
2012-12-03 | bsps/powerpc: Add .nvram section | Sebastian Huber | 1 | -2/+4 | |
2012-06-12 | bsps: Replace NIRVANA region | Sebastian Huber | 1 | -3/+2 | |
Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS" region. Move the region definition into the "linkcmds.base" files. | |||||
2012-06-04 | bsps/powerpc: Add load section for .nocache | Sebastian Huber | 1 | -1/+2 | |
2012-04-24 | bsps/powerpc: Add no cache section | Sebastian Huber | 1 | -0/+1 | |
2011-07-21 | 2011-07-21 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 1 | -0/+33 | |
PR 1799/bsps * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac, clock/clock-config.c, console/console-config.c, console/uart-bridge-master.c, console/uart-bridge-slave.c, include/.cvsignore, include/bsp.h, include/hwreg_vals.h, include/intercom.h, include/irq.h, include/mmu.h, include/qoriq.h, include/tm27.h, include/tsec-config.h, include/u-boot-config.h, include/uart-bridge.h, irq/irq.c, make/custom/qoriq.inc, make/custom/qoriq_core_0.cfg, make/custom/qoriq_core_1.cfg, make/custom/qoriq_p1020rdb.cfg, network/if_intercom.c, network/network.c, rtc/rtc-config.c, shmsupp/intercom-mpci.c, shmsupp/intercom.c, shmsupp/lock.S, start/start.S, startup/bsppredriverhook.c, startup/bspreset.c, startup/bspstart.c, startup/linkcmds.base, startup/linkcmds.qoriq_core_0, startup/linkcmds.qoriq_core_1, startup/linkcmds.qoriq_p1020rdb, startup/mmu-config.c, startup/mmu-tlb1.S, startup/mmu.c: New files. |
