2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2022-07-12 | bsps/powerpc/qoriq: Change license to BSD-2 | Joel Sherrill | 1 | -3/+22 | |
Updates #3053. | |||||
2022-03-10 | bsps/powerpc/: Scripted embedded brains header file clean up | Joel Sherrill | 1 | -6/+0 | |
Updates #4625. | |||||
2019-03-08 | bsps: Adjust bsp.h Doxygen groups | Sebastian Huber | 1 | -1/+1 | |
Update #3706. | |||||
2018-04-20 | bsps: Move startup files to bsps | Sebastian Huber | 1 | -0/+0 | |
Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285. | |||||
2017-11-22 | bsp/qoriq: Implement bsp_reset() | Sebastian Huber | 1 | -5/+37 | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2011-07-21 | 2011-07-21 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 1 | -4/+16 | |
PR 1799/bsps * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac, clock/clock-config.c, console/console-config.c, console/uart-bridge-master.c, console/uart-bridge-slave.c, include/.cvsignore, include/bsp.h, include/hwreg_vals.h, include/intercom.h, include/irq.h, include/mmu.h, include/qoriq.h, include/tm27.h, include/tsec-config.h, include/u-boot-config.h, include/uart-bridge.h, irq/irq.c, make/custom/qoriq.inc, make/custom/qoriq_core_0.cfg, make/custom/qoriq_core_1.cfg, make/custom/qoriq_p1020rdb.cfg, network/if_intercom.c, network/network.c, rtc/rtc-config.c, shmsupp/intercom-mpci.c, shmsupp/intercom.c, shmsupp/lock.S, start/start.S, startup/bsppredriverhook.c, startup/bspreset.c, startup/bspstart.c, startup/linkcmds.base, startup/linkcmds.qoriq_core_0, startup/linkcmds.qoriq_core_1, startup/linkcmds.qoriq_p1020rdb, startup/mmu-config.c, startup/mmu-tlb1.S, startup/mmu.c: New files. | |||||
2010-12-30 | 2010-12-30 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 1 | -11/+7 | |
* include/u-boot.h: Removed file. * include/u-boot-config.h: New file. * include/bsp.h, start/start.S, startup/bspstart.c: Use new U-Boot support. * Makefile.am, preinstall.am: Reflect changes above. | |||||
2010-12-03 | 2010-12-03 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 1 | -0/+26 | |
* preinstall.am, shared/lpc/include/lpc-i2s.h, shared/startup/linkcmds.armv4, shared/startup/linkcmds.armv7: New files. * Makefile.am: Added header and linker command files intended to be used by every ARM BSP. * shared/startup/linkcmds.base: Support for EABI and ARM ELF standard. * shared/include/linker-symbols.h: Update due to linker command file changes. * shared/start/start.S, shared/include/start.h: Renamed entry symbol from start to _start to avoid namespace conflicts. Update due to linker command file changes. |
