path: root/bsps/powerpc/qoriq/include (follow)
* bsps: Adjust bsp.h Doxygen groupsSebastian Huber2019-03-088-22/+34
| | | | Update #3706.
* bsp/qoriq: Add struct qoriq to allow forward declsSebastian Huber2018-09-061-2/+2
* qoriq/include/tm27.h: Fix warningsJoel Sherrill2018-08-291-5/+5
* qoriq/include/tm27.h: Fix prototype warningJoel Sherrill2018-08-101-2/+2
* bsps: bsp_start_on_secondary_processor()Sebastian Huber2018-07-251-1/+3
| | | | | | Pass current processor control as first parameter in bsp_start_on_secondary_processor() and qoriq_start_thread() to make dependency more explicit.
* Remove make preinstallChris Johns2018-01-2511-0/+2842
