line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
PR 1799/bsps
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
clock/clock-config.c, console/console-config.c,
console/uart-bridge-master.c, console/uart-bridge-slave.c,
include/.cvsignore, include/bsp.h, include/hwreg_vals.h,
include/intercom.h, include/irq.h, include/mmu.h, include/qoriq.h,
include/tm27.h, include/tsec-config.h, include/u-boot-config.h,
include/uart-bridge.h, irq/irq.c, make/custom/qoriq.inc,
make/custom/qoriq_core_0.cfg, make/custom/qoriq_core_1.cfg,
make/custom/qoriq_p1020rdb.cfg, network/if_intercom.c,
network/network.c, rtc/rtc-config.c, shmsupp/intercom-mpci.c,
shmsupp/intercom.c, shmsupp/lock.S, start/start.S,
startup/bsppredriverhook.c, startup/bspreset.c, startup/bspstart.c,
startup/linkcmds.base, startup/linkcmds.qoriq_core_0,
startup/linkcmds.qoriq_core_1, startup/linkcmds.qoriq_p1020rdb,
startup/mmu-config.c, startup/mmu-tlb1.S, startup/mmu.c: New files.
