path: root/bsps/powerpc/qoriq/include/bsp/intercom.h (follow)
* bsps/powerpc/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+0
| | | | Updates #4625.
* bsps: Adjust bsp.h Doxygen groupsSebastian Huber2019-03-081-2/+2
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+125
