Update #3970.
Add new BSP system initialization step for work to be performed before
the work areas are initialized.
Update #3838.
Remove parameters from ppc_exc_initialize() since all BSPs passed the
same values.
Update #3459.
Statically initialize the interrupt stack area
(_Configuration_Interrupt_stack_area_begin,
_Configuration_Interrupt_stack_area_end, and
_Configuration_Interrupt_stack_size) via <rtems/confdefs.h>. Place the
interrupt stack area in a special section ".rtemsstack.interrupt". Let
BSPs define the optimal placement of this section in their linker
command files (e.g. in a fast on-chip memory).
This change makes makes the CPU_HAS_SOFTWARE_INTERRUPT_STACK and
CPU_HAS_HARDWARE_INTERRUPT_STACK CPU port defines superfluous, since the
low level initialization code has all information available via global
symbols.
This change makes the CPU_ALLOCATE_INTERRUPT_STACK CPU port define
superfluous, since the interrupt stacks are allocated by confdefs.h for
all architectures. There is no need for BSP-specific linker command
file magic (except the section placement), see previous ARM linker
command file as a bad example.
Remove _CPU_Install_interrupt_stack(). Initialize the hardware
interrupt stack in _CPU_Initialize() if necessary (e.g.
m68k_install_interrupt_stack()).
The optional _CPU_Interrupt_stack_setup() is still useful to customize
the registration of the interrupt stack area in the per-CPU information.
The initialization stack can reuse the interrupt stack, since
* interrupts are disabled during the sequential system initialization,
and
* the boot_card() function does not return.
This stack resuse saves memory.
Changes per architecture:
arm:
* Mostly replace the linker symbol based configuration of stacks with
the standard <rtems/confdefs.h> configuration via
CONFIGURE_INTERRUPT_STACK_SIZE. The size of the FIQ, ABT and UND
mode stack is still defined via linker symbols. These modes are
rarely used in applications and the default values provided by the
BSP should be sufficient in most cases.
* Remove the bsp_processor_count linker symbol hack used for the SMP
support. This is possible since the interrupt stack area is now
allocated by the linker and not allocated from the heap. This makes
some configure.ac stuff obsolete. Remove the now superfluous BSP
variants altcycv_devkit_smp and realview_pbx_a9_qemu_smp.
bfin:
* Remove unused magic linker command file allocation of initialization
stack. Maybe a previous linker command file copy and paste problem?
In the start.S the initialization stack is set to a hard coded value.
lm32, m32c, mips, nios2, riscv, sh, v850:
* Remove magic linker command file allocation of initialization stack.
Reuse interrupt stack for initialization stack.
m68k:
powerpc:
* Used dedicated memory region (REGION_RTEMSSTACK) for the interrupt
stack on BSPs using the shared linkcmds.base (replacement for
REGION_RWEXTRA).
sparc:
* Remove the hard coded initialization stack. Use the interrupt stack
for the initialization stack on the boot processor. This saves
16KiB of RAM.
Update #3459.
Add rtems_counter_frequency() API function. Use it to initialize the
counter value converter via the new system initialization step
(RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation
and the counter converter. It avoids an unnecessary pull in of the
64-bit integer division from libgcc.
Update #3456.
Update #3285.
Update #2408.
BSPs can use the bsp_fatal_extension() to provide BSP-specific fatal
error handling. There is no need for a _BSP_Fatal_error().
Close #3246.
Due to a new rtems_panic() implementation, it is possible to replace the
PowerPC-specific BSP_panic() with rtems_panic(). Remove BSP_panic()
implementations.
Close #3245.
Update #2408.
Also use the const qualifier on the address pointer's target in in_*()
Closes #2128
warning and clean up
Instead of SPRG0 (= special purpose register 272) use the new global
symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask.
The benefit is that it is now possible to disable interrupts without
further run-time initialization in boot_card().
At least on Freescale e500 cores this leads also to a faster execution
since the mfmsr and mfspr instruction require four cycles to complete.
The instructions to load the mask value can execute while the mfmsr is
in progress.
PR 1685/bsps
* startup/bspstart.c: Add BSP_poll_char.
* startup/bspstart.c, startup/misc.c:
Fixed compiler warnings by adding prototypes to function
declarations and moving extern declarations to global scope.
* start/start.S, startup/bspstart.c:
let 'save_boot_params()' return a pointer to the commandline
saved by the BSP and pass this pointer on to 'boot_card()'.
* include/bsp.h, start/start.S, startup/bspstart.c:
removed BSP_INIT_STACK_SIZE -- this BSP now also uses
__stack defined by the linker script for the initial
stack.
Removed legacy code (inherited from old mvme2307 BSP
but not relevant to this one) that tested trapping
into PPCBug.
* Makefile.am, configure.ac, include/bsp.h, include/bspopts.h.in,
startup/bspstart.c: Add use of bsp_get_work_area() in its own file
and rely on BSP Framework to perform more initialization.
* startup/bspstart.c: Review of all bsp_cleanup() implementations. In
this phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* startup/bspstart.c: removed warning about SPRG0
now being used for IRQ mask; this BSP is OK.
* include/bsp.h, startup/bspstart.c: confdefs.h now wants
us to use BSP_INTERRUPT_STACK_SIZE instead of
CONFIGURE_INTERRUPT_STACK_MEMORY. Removed reference to
CONFIGURE_INTERRUPT_STACK_MEMORY from bspstart.c
* start/start.S, startup/bspstart.c: disable memory-select
errors early (in start.S) to avoid hangs due to speculative
memory access (motload maps absent memory in TLBs).
Remove TLB mappings for which no physical memory is installed
(bspstart). Enable HID1[RFXE] so that 'core_fault_in' errors
result in a machine-check rather than stalling the machine.
Re-enable memory-select errors at this point.
* startup/bspstart.c: Fixes a lockup which occurs when a speculative
load occurs from a particular range of memory.
