2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2022-07-12 | bsps/powerpc/mpc55xxevb: Change license to BSD-2 | Joel Sherrill | 1 | -3/+22 | |
Updates #3053. | |||||
2022-03-10 | bsps/powerpc/: Scripted embedded brains header file clean up | Joel Sherrill | 1 | -6/+0 | |
Updates #4625. | |||||
2018-04-20 | bsps: Move startup files to bsps | Sebastian Huber | 1 | -0/+0 | |
Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285. | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2012-10-02 | bsp/mpc55xx: Add and use MPC55XX_CHIP_FAMILY | Sebastian Huber | 1 | -1/+1 | |
2012-07-18 | bsp/mpc55xx: Add MPC55XX_NEEDS_LOW_LEVEL_INIT | Sebastian Huber | 1 | -0/+4 | |
2012-05-21 | powerpc/mpc55xxevb: Fix cache define usage | Sebastian Huber | 1 | -5/+9 | |
2012-01-23 | Support for MPC5643L. | Sebastian Huber | 1 | -0/+106 | |
Rework of the start sequence to reduce the amount assembler code and to support configuration tables which may be provided by the application. |
