path: root/bsps/powerpc/mpc55xxevb/include/mpc55xx/dspi.h (unfollow)
2023-05-20Update company nameSebastian Huber1-1/+1
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
2022-07-12bsps/powerpc/mpc55xxevb: Change license to BSD-2Joel Sherrill1-3/+22
Updates #3053.
2022-03-10bsps/powerpc/: Scripted embedded brains header file clean upJoel Sherrill1-7/+1
Updates #4625.
2019-03-08bsps: Adjust bsp.h Doxygen groupsSebastian Huber1-1/+1
Update #3706.
2019-03-07bsps/powerpc: Move mpc55xx header filesSebastian Huber1-0/+0
They are only used by this BSP.
2018-01-25Remove make preinstallChris Johns1-0/+0
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2013-04-08bsp/mpc55xx: eDMA API changesSebastian Huber1-3/+8
2012-10-11Use proper 3 line form of license textJoel Sherrill1-2/+3
2009-11-30Whitespace removal.Ralf Corsepius1-2/+2
2009-07-21Update for MPC55XX changesThomas Doerfler1-29/+16
2008-07-14updated gen83xx BSPThomas Doerfler1-0/+135
updated haleakala BSP added MPC55xx BSP
