brains GmbH.
The shared BSP interrupt controller support code actually implements
parts of the Interrupt Manager.
Update #3706.
The name handler table was a bit misleading after the last rework.
Rename it to distach table. Update the documentation accordingly.
Update #4769.
Updates #3053.
Updates #4625.
This define is no longer used.
Update #3269.
Assert BSP_INTERRUPT_VECTOR_MAX + 1 == BSP_INTERRUPT_VECTOR_COUNT.
After building all BSPs with this patch, BSP_INTERRUPT_VECTOR_MAX can be
removed and replaced by BSP_INTERRUPT_VECTOR_COUNT. The
BSP_INTERRUPT_VECTOR_COUNT allows a default implementation which supports no
interrupt vector at all. Using COUNT instead of MAX may avoid some
interpretation issues, for example is the maximum value a valid vector number
or not.
Update #3269.
Remove BSP_INTERRUPT_VECTOR_MIN and unconditionally let interrupt vector
numbers start with zero.
The BSP_INTERRUPT_VECTOR_MIN == 0 invariant was tested by the previous commit
and building all BSPs.
Update #3269.
Remove the support for BSP_INTERRUPT_NO_HEAP_USAGE. This was only used
by one BSP and provides no real benefit.
Update #3269.
Update #3706.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
Update #3268.
Rework of the start sequence to reduce the amount assembler code and to
support configuration tables which may be provided by the application.
* new-exceptions/bspsupport/ppc_exc_async_normal.S: Bugfix for
MPC5674F. Use it for all to be safe.
* mpc55xx/include/emios.h: Fixed eMIOS module count.
* mpc55xx/include/irq.h: Fixed CAN vector numbers.
BSP_INTERRUPT_HANDLER_TABLE_SIZE is now a BSP option.
* mpc55xx/include/fsl-mpc551x.h, mpc55xx/include/fsl-mpc555x.h,
mpc55xx/include/fsl-mpc556x.h, mpc55xx/include/fsl-mpc567x.h,
mpc55xx/include/regs-edma.h, mpc55xx/include/regs-mmu.h: New files.
* Makefile.am, M preinstall.am: Reflect changes above.
* mpc55xx/dspi/dspi.c: Update due to API changes.
* mpc55xx/include/edma.h, mpc55xx/edma/edma.c: Rework to support
multiple eDMA modules. Removed complex error interrupt handling.
* mpc55xx/include/esci.h, mpc55xx/esci/esci.c: Support interrupt mode
and printk(). Use configure options.
* mpc55xx/include/irq.h: More defines. API changes.
* mpc55xx/include/mpc55xx.h: API changes.
* mpc55xx/include/reg-defs.h: Added register defines.
* mpc55xx/include/regs.h: Use new register header files.
* mpc55xx/include/siu.h: Fixed includes.
* mpc55xx/misc/fmpll.S, mpc55xx/misc/copy.S, mpc55xx/misc/flash.S:
Changed sections. API changes. Support MPC5674F.
* mpc55xx/include/irq.h: Include missing <bspopts.h>. Format.
* mpc83xx/include/mpc83xx.h, mpc83xx/i2c/mpc83xx_i2cdrv.h,
mpc83xx/i2c/mpc83xx_i2cdrv.c: Changes to use this driver for the
MPC55XX familiy.
* libcpu/powerpc/mpc55xx/include/irq.h: Move defines from
'libbsp/powerpc/mpc55xxevb/include/irq-config.h'.
* libbsp/powerpc/mpc55xxevb/include/irq-config.h: Removed file.
* libbsp/powerpc/mpc55xxevb/Makefile.am,
libbsp/powerpc/mpc55xxevb/preinstall.am: Reflect changes above.
updated haleakala BSP
added MPC55xx BSP
