2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2022-07-12 | bsps/powerpc/mpc55xxevb: Change license to BSD-2 | Joel Sherrill | 1 | -3/+22 | |
Updates #3053. | |||||
2022-03-10 | bsps/powerpc/: Scripted embedded brains header file clean up | Joel Sherrill | 1 | -6/+0 | |
Updates #4625. | |||||
2018-04-20 | bsps: Move console drivers to bsps | Sebastian Huber | 1 | -0/+0 | |
This patch is a part of the BSP source reorganization. Update #3285. | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2012-07-25 | bsp/mpc55xx: Add MPC55XX_CONSOLE_MINOR | Sebastian Huber | 1 | -1/+2 | |
Remove MPC55XX_ESCI_CONSOLE_MINOR. | |||||
2012-07-18 | bsp/mpc55xx: Add ESCI_C and ESCI_D support | Sebastian Huber | 1 | -3/+11 | |
2012-01-23 | Support for MPC5643L. | Sebastian Huber | 1 | -0/+32 | |
Rework of the start sequence to reduce the amount assembler code and to support configuration tables which may be provided by the application. |
