The <rtems/irq.h> defines a legacy API.
brains GmbH.
Updates #3053.
Updates #4625.
Updates #4625.
Update #3866.
- These calls clash with the Linux IO header in LibBSD. Making these
conditional here means BSPs build and the imported Linux header is
untouched.
Updates #4245
- Add support to the BSP to enable irq-generic management
- Update the powerpc shared irq code to support irq-generic. This
is an opt in option for existing powerpc bsps. This change
should be simpler now
- Fix a number of issues in ISA IRQ controller handling by porting
fixes from the i386 (PC) BSP
Closes #4238
Closes #4239
Do not force BSPs to define __ppc_generic.
This was probably the last command line define in the BSPs.
GCC 10 no longer passes -many to the assembler. This enables more
checks in the assembler.
The 0 in the tlbie instruction is the L operand which selects a 4KiB
page size.
Update #3122.
Update #3706.
They are only used by this BSP.
They are only used by PowerPC BSPs.
replace.
searching and sorting.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
Fix small data area in case no fixed size is desired. Rename
bsp_section_set_sdata_sbss_size into bsp_section_small_data_area_size
since this symbol reflects the overall small data area size (including
space for libdl). Do not use bsp_section_sbss_size before definition in
linker command file. Add new symbols to <bsp/linker-symbols.h>.
Update #3687.
We have to be careful with instructions which operate explicitly on
words or doublewords.
Update #3082.
Rename
* _Configuration_Interrupt_stack_area_begin in _ISR_Stack_area_begin,
* _Configuration_Interrupt_stack_area_end in _ISR_Stack_area_end, and
* _Configuration_Interrupt_stack_size in _ISR_Stack_size.
Move definitions to <rtems/score/isr.h>. The new names are considerable
shorter and in the right namespace.
Update #3459.
Update #3513.
Remove parameters from ppc_exc_initialize() since all BSPs passed the
same values.
Update #3459.
Use a dedicated memory region or place it between the BSS and workspace.
Update #3459.
The ppc405 define must be checked before the ppc403 define. The ppc405
define is provided by <bspopts.h>. The ppc403 define is provided by GCC
as a built-in define if no ppc* or mpc* define is set via the
command line (see GCC sources "gcc/config/rs6000/rtems.h").
Update #3425.
The VME support is only used by powerpc BSPs.
Update #3285.
Started to eliminate warnings and then realized that only one one-line
macro in the file was used by a few files. The rest of the file was
was not needed. Eliminate the file.
Closes #3354.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
