line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* mpc5xx/console-generic/console-generic.c, mpc5xx/include/console.h,
mpc8260/console-generic/console-generic.c, mpc8260/include/console.h,
mpc8xx/console-generic/console-generic.c, mpc8xx/include/console.h:
Remove all references to console_reserve_resources and
termios_reserve_resources.
* Added mpc8260 directory.
* Modified Makefile.am and configure.in to build the contents
* mpc8260/Makefile.am, mpc8260/README, mpc8260/clock/Makefile.am,
mpc8260/clock/clock.c, mpc8260/console-generic/Makefile.am,
mpc8260/console-generic/console-generic.c, mpc8260/cpm/.cvsignore,
mpc8260/cpm/Makefile.am, mpc8260/cpm/brg.c, mpc8260/cpm/cp.c,
mpc8260/cpm/dpram.c, mpc8260/exceptions/.cvsignore,
mpc8260/exceptions/Makefile.am, mpc8260/exceptions/asm_utils.S,
mpc8260/exceptions/raw_exception.c, mpc8260/exceptions/raw_exception.h,
mpc8260/include/Makefile.am, mpc8260/include/console.h,
mpc8260/include/cpm.h, mpc8260/include/mmu.h,
mpc8260/include/mpc8260.h, mpc8260/mmu/Makefile.am, mpc8260/mmu/mmu.c,
mpc8260/timer/Makefile.am, mpc8260/timer/timer.c: New files.
