2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2022-07-12 | bsps/powerpc/gen5200: Change license to BSD-2 | Joel Sherrill | 1 | -3/+22 | |
Updates #3053. | |||||
2022-03-10 | bsps/powerpc/: Scripted embedded brains header file clean up | Joel Sherrill | 1 | -6/+0 | |
Updates #4625. | |||||
2018-08-07 | bsp/gen5200: Avoid deprecated routine | Sebastian Huber | 1 | -1/+3 | |
Update #3358. | |||||
2018-04-23 | bsps: Move ATA drivers to bsps | Sebastian Huber | 1 | -0/+0 | |
This patch is a part of the BSP source reorganization. Update #3285. | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2014-02-19 | score: Add RTEMS_FATAL_SOURCE_BSP | Sebastian Huber | 1 | -1/+2 | |
Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to figure out the code position given a fatal source and code. | |||||
2013-02-20 | bsp/gen5200: New ATA driver | Sebastian Huber | 1 | -0/+40 | |
This is a replacement for the ATA task. The performance is much better. |
