Update #3866.
Update #3838.
Update #3706.
replace.
searching and sorting.
Update #3706.
Use a dedicated memory region or place it between the BSS and workspace.
Update #3459.
This is unused copy and paste stuff.
Update #3459.
Update #3285.
* bsps/shared/cache
Update #3285.
