path: root/bsps/or1k/generic_or1k/include/bsp/uart.h (unfollow)
2019-03-08bsps: Adjust bsp.h Doxygen groupsSebastian Huber1-1/+1
Update #3706.
2018-01-25Remove make preinstallChris Johns1-0/+0
2015-04-19Rename or1ksim BSP to generic_or1kHesham ALMatary1-10/+10
or1ksim BSP was initially named after or1ksim simulator, and it was intented to only run there. But now it can also run on QEMU, jor1k and real FPGA boards without modifications. It makes more sense to give it a new generic name like generic_or1k.
2014-08-20Add new (first) OpenRISC BSP called or1ksim.Hesham ALMatary1-0/+42
This BSP is intended to run on or1ksim (the main OpenRISC emulator). Fixed version according to Joel comments from the mailing list.
