Updates #3053.
Update #3706.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
do
echo $b
# echo $g
-i $b
done
This file defines at least the POW() macro which pollutes the
public name space and causes warnings in at least the paranoia
sample application.
Changed console driver to use interrupts instead of polling.
Change to avoid overwriting CPU32Bug interrupt vector when setting up the Sci interrupt handler.
Fixed type for boolean flag in bsp.h.
Changed mrm332.h to use 25Mhz clock.
Fixes to mrm332.cfg to use correct mcpu32 value for RTEMS_CPU_MODEL instead of m68332 which is no longer supported.
Added -mcpu=cpu32 to compiler options.
Removed broken ROM linker script and replaced broken RAM linker script with working ROM linker script.
Removed no longer required file except_vect_332_ROM.S.
Enabled 0xbeefbeef magic string in start.S to allow MRM version of CPU32Bug to auto run RTEMS.
Removed old code from start.S
Changed compiler optimization flag to optimize for size.
* include/bsp.h, include/mrm332.h, spurious/spinit.c:
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* include/bsp.h: Defined as a small memory target. It cannot build
one of the sample programs any more.
* include/bsp.h: Remove unnecessary boilerplate comments.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* clock/ckinit.c, include/bsp.h, startup/bspstart.c: Eliminate copies
of the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* include/bsp.h: Remove redundant prototypes.
* include/bsp.h: New header guard.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* c/src/lib/libbsp/m68k/mrm332/include/bsp.h,
c/src/lib/libbsp/m68k/mrm332/start/start.S,
c/src/lib/libbsp/m68k/mrm332/startup/start_c.c: Include
<rtems/m68k/sim.h> instead of <sim.h>.
* c/src/lib/libbsp/m68k/mrm332/include/bsp.h: Include
<rtems/m68k/qsm.h> instead of <qsm.h>.
* clock/ckinit.c, console/sci.c, console/sci.h, include/bsp.h,
misc/interr.c, startup/bspstart.c, timer/timer.c: Convert to using
c99 fixed size types.
* clock/ckinit.c, console/console.c, include/bsp.h, misc/interr.c,
spurious/spinit.c, startup/bspclean.c, startup/bspstart.c,
timer/timer.c: URL for license changed.
* console/sci.c, console/sci.h,
console/console.c: Added new SCI driver.
* start/start.c: Removed file.
* start/start.S: New file, the asm portion of the updated start code.
* start/configure.am: Added start.S, removed start.c
* startup/start_c.c: New file, the C portion of the updated start code. Contains most of the code that was in the old start.c.
* startup/configure.am: Added start_c.c to C_FILES.
* include/bsp.h: Added include <rtems/bspIo.h>
* .cvsignore, ChangeLog Makefile.am, README, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in,
console/.cvsignore, console/Makefile.am, console/console.c,
include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c,
spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c,
start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM,
timer/.cvsignore, timer/Makefile.am, timer/timer.c, times,
wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
and memory layout. Next step is to share the same bsp_pretasking_hook.
that converts the libbsp/i386 subdirectory to full automake.
commit them.
like signal dispatching.
