Updates #3053.
Use a system initialization handler instead of a legacy IO driver.
Update #3834.
This function is no longer supported by the standard clock driver
implementation (clockimpl.h).
Update #3436.
Update #3285.
This file defines at least the POW() macro which pollutes the
public name space and causes warnings in at least the paranoia
sample application.
* Makefile.am, configure.ac, clock/ckinit.c, startup/linkcmds,
startup/linkcmds_ROM: Add use of bsp_get_work_area() in its own file
and rely on BSP Framework to perform more initialization. Remove
unnecessary includes of rtems/libio.h and rtems/libcsupport.h.
* startup/bsppredriverhook.c: New file.
* clock/ckinit.c: The Shared Memory Driver no longer requires the
special IOCTL in Clock_control. This was a hack which has existed
since before the Classic API Timer Manager was implemented. All
implementations of and references to Clock_control were removed.
* clock/ckinit.c, include/bsp.h, startup/bspstart.c: Eliminate copies
of the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* clock/ckinit.c, console/sci.c, console/sci.h, include/bsp.h,
misc/interr.c, startup/bspstart.c, timer/timer.c: Convert to using
c99 fixed size types.
* clock/ckinit.c, console/console.c, include/bsp.h, misc/interr.c,
spurious/spinit.c, startup/bspclean.c, startup/bspstart.c,
timer/timer.c: URL for license changed.
* .cvsignore, ChangeLog Makefile.am, README, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in,
console/.cvsignore, console/Makefile.am, console/console.c,
include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c,
spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c,
start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM,
timer/.cvsignore, timer/Makefile.am, timer/timer.c, times,
wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
commit them.
like signal dispatching.
