path: root/bsps/m68k/mcf5235/headers.am (unfollow)
2021-09-21build: Remove old build systemSebastian Huber1-10/+0
Close #3250. Close #4081.
2019-07-05bsps: Regenerate headers.amSebastian Huber1-0/+4
Update #3269.
2018-01-25Remove make preinstallChris Johns1-0/+6
