Add TM27_USE_VECTOR_HANDLER to select the interrupt handler type used by
the <tm27.h> implementation.
Close #4820.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, gdb-init,
preinstall.am, clock/clock.c, console/console.c, console/debugio.c,
include/bsp.h, include/tm27.h, make/custom/mcf5225x.cfg,
start/start.S, startup/bspclean.c, startup/bspstart.c,
startup/init5225x.c, startup/linkcmds, timer/timer.c: New files.
* .cvsignore, Makefile.am, README, bsp_specs, configure.ac,
clock/clock.c, console/console.c, include/bsp.h,
include/bspopts.h.in, include/coverhd.h, include/tm27.h,
network/network.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/init5282.c, startup/linkcmds,
startup/linkcmdsflash, startup/linkcmdsram, timer/timer.c: New files.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
clock/clock.c, console/console.c, include/bsp.h, include/coverhd.h,
include/tm27.h, network/network.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/init5235.c, startup/linkcmds,
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
