path: root/bsps/m68k/include/mcf532x/mcf532x.h (unfollow)
2018-01-25Remove make preinstallChris Johns1-0/+0
2008-07-042008-07-04 Matthew Riek <matthew.riek@ibiscomputer.com.au>Joel Sherrill1-1/+24
* Makefile.am, mcf532x/include/mcf532x.h, shared/cache/cache_.h: Add cache support for 5329. Enable the cache in copyback and write-through so we can assume that in BSP. * mcf532x/cache/cachepd.c: New file.
2008-06-202008-06-20 Matthew Riek <matthew.riek@ibiscomputer.com.au>Joel Sherrill1-0/+4460
* Makefile.am, configure.ac, preinstall.am: Adding mcf5329 BSP and CPU support. * mcf532x/include/mcf532x.h: New file.
