brains GmbH.
Updates #3053.
Quite some files in the bsps/m68k/genmcf548x mention a
Freescale_license.txt file. The file has been accidentally removed
during the source reorganization in 2018. This commit restores it and
moves it to the right location for licenses.
Update #4625.
Updates #4625.
Update #3706.
replace.
searching and sorting.
Update #3706.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
warnings
These files were left after running the script in the previous patch.
Add doxygen to the header files in the genmcf548x/include directory.
According to the manual the application must use unique and
non-overlapping level and priority definitions for enabled interrupts.
* include/bsp.h: Remove unnecessary boilerplate comments.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
added genmcf548x BSP
