Close #3250.
Close #4081.
Update #3866.
This fixes an issue with the latest tool chain which adds the default
linker script in the endfile specification.
Update #3250.
Update #3838.
Use a system initialization handler instead of a legacy IO driver.
Update #3834.
This function is no longer supported by the standard clock driver
implementation (clockimpl.h).
Update #3436.
Update #3269.
controller support.
Update #3269.
Update #3706.
replace.
searching and sorting.
Update #3706.
The size of the sample executables without this option were:
65600 4384 19280 89264 15cb0 ./m68k-rtems5/c/gen68340/testsuites/samples/base_sp.exe
199728 5504 22688 227920 37a50 ./m68k-rtems5/c/gen68340/testsuites/samples/capture.exe
233024 6160 20288 259472 3f590 ./m68k-rtems5/c/gen68340/testsuites/samples/cdtest.exe
829632 25152 27008 881792 d7480 ./m68k-rtems5/c/gen68340/testsuites/samples/cxx_iostream.exe
539072 8048 32144 579264 8d6c0 ./m68k-rtems5/c/gen68340/testsuites/samples/fileio.exe
100320 4752 19440 124512 1e660 ./m68k-rtems5/c/gen68340/testsuites/samples/hello.exe
240080 9264 26048 275392 433c0 ./m68k-rtems5/c/gen68340/testsuites/samples/loopback.exe
36784 3584 15152 55520 d8e0 ./m68k-rtems5/c/gen68340/testsuites/samples/minimum.exe
89104 4864 19408 113376 1bae0 ./m68k-rtems5/c/gen68340/testsuites/samples/nsecs.exe
175200 5152 20016 200368 30eb0 ./m68k-rtems5/c/gen68340/testsuites/samples/paranoia.exe
422944 15456 49312 487712 77120 ./m68k-rtems5/c/gen68340/testsuites/samples/pppd.exe
68768 4416 19312 92496 16950 ./m68k-rtems5/c/gen68340/testsuites/samples/ticker.exe
68816 4368 23200 96384 17880 ./m68k-rtems5/c/gen68340/testsuites/samples/unlimited.exe
The size of the sample executables with this option enabled were:
54384 4384 19200 77968 13090 ./m68k-rtems5/c/gen68340/testsuites/samples/base_sp.exe
177648 5488 22640 205776 323d0 ./m68k-rtems5/c/gen68340/testsuites/samples/capture.exe
159392 5344 20208 184944 2d270 ./m68k-rtems5/c/gen68340/testsuites/samples/cdtest.exe
158720 5424 20432 184576 2d100 ./m68k-rtems5/c/gen68340/testsuites/samples/cxx_iostream.exe
515696 8016 31792 555504 879f0 ./m68k-rtems5/c/gen68340/testsuites/samples/fileio.exe
83920 4736 19392 108048 1a610 ./m68k-rtems5/c/gen68340/testsuites/samples/hello.exe
206640 9168 25920 241728 3b040 ./m68k-rtems5/c/gen68340/testsuites/samples/loopback.exe
21232 3520 15104 39856 9bb0 ./m68k-rtems5/c/gen68340/testsuites/samples/minimum.exe
78352 4864 19312 102528 19080 ./m68k-rtems5/c/gen68340/testsuites/samples/nsecs.exe
159600 5136 19968 184704 2d180 ./m68k-rtems5/c/gen68340/testsuites/samples/paranoia.exe
377376 15296 48528 441200 6bb70 ./m68k-rtems5/c/gen68340/testsuites/samples/pppd.exe
58304 4416 19232 81952 14020 ./m68k-rtems5/c/gen68340/testsuites/samples/ticker.exe
59360 4336 23168 86864 15350 ./m68k-rtems5/c/gen68340/testsuites/samples/unlimited.exe
Closes #2573.
Update #3585.
Update #3598.
Rename
* _Configuration_Interrupt_stack_area_begin in _ISR_Stack_area_begin,
* _Configuration_Interrupt_stack_area_end in _ISR_Stack_area_end, and
* _Configuration_Interrupt_stack_size in _ISR_Stack_size.
Move definitions to <rtems/score/isr.h>. The new names are considerable
shorter and in the right namespace.
Update #3459.
Statically initialize the interrupt stack area
(_Configuration_Interrupt_stack_area_begin,
_Configuration_Interrupt_stack_area_end, and
_Configuration_Interrupt_stack_size) via <rtems/confdefs.h>. Place the
interrupt stack area in a special section ".rtemsstack.interrupt". Let
BSPs define the optimal placement of this section in their linker
command files (e.g. in a fast on-chip memory).
This change makes makes the CPU_HAS_SOFTWARE_INTERRUPT_STACK and
CPU_HAS_HARDWARE_INTERRUPT_STACK CPU port defines superfluous, since the
low level initialization code has all information available via global
symbols.
This change makes the CPU_ALLOCATE_INTERRUPT_STACK CPU port define
superfluous, since the interrupt stacks are allocated by confdefs.h for
all architectures. There is no need for BSP-specific linker command
file magic (except the section placement), see previous ARM linker
command file as a bad example.
Remove _CPU_Install_interrupt_stack(). Initialize the hardware
interrupt stack in _CPU_Initialize() if necessary (e.g.
m68k_install_interrupt_stack()).
The optional _CPU_Interrupt_stack_setup() is still useful to customize
the registration of the interrupt stack area in the per-CPU information.
The initialization stack can reuse the interrupt stack, since
* interrupts are disabled during the sequential system initialization,
and
* the boot_card() function does not return.
This stack resuse saves memory.
Changes per architecture:
arm:
* Mostly replace the linker symbol based configuration of stacks with
the standard <rtems/confdefs.h> configuration via
CONFIGURE_INTERRUPT_STACK_SIZE. The size of the FIQ, ABT and UND
mode stack is still defined via linker symbols. These modes are
rarely used in applications and the default values provided by the
BSP should be sufficient in most cases.
* Remove the bsp_processor_count linker symbol hack used for the SMP
support. This is possible since the interrupt stack area is now
allocated by the linker and not allocated from the heap. This makes
some configure.ac stuff obsolete. Remove the now superfluous BSP
variants altcycv_devkit_smp and realview_pbx_a9_qemu_smp.
bfin:
* Remove unused magic linker command file allocation of initialization
stack. Maybe a previous linker command file copy and paste problem?
In the start.S the initialization stack is set to a hard coded value.
lm32, m32c, mips, nios2, riscv, sh, v850:
* Remove magic linker command file allocation of initialization stack.
Reuse interrupt stack for initialization stack.
m68k:
powerpc:
* Used dedicated memory region (REGION_RTEMSSTACK) for the interrupt
stack on BSPs using the shared linkcmds.base (replacement for
REGION_RWEXTRA).
sparc:
* Remove the hard coded initialization stack. Use the interrupt stack
for the initialization stack on the boot processor. This saves
16KiB of RAM.
Update #3459.
Use a dedicated memory region or place it between the BSS and workspace.
Update #3459.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
