This cleans up outputUsesInterrupts usage with rtems_termios_device_mode
enum values. The outputUsesInterrupts member was typed as an int, named
as if it were a boolean value, and used as if it were a
rtems_termios_device_mode enum. In this patch, values assigned to
outputUsesInterrupts have been converted to the corresponding
rtems_termios_device_mode enum value, conversions from
deviceOutputUsesInterrupts have been made explicit, and uses of
rtems_termios_device_mode enum values with deviceOutputUsesInterrupts
have been converted to booleans.
Updates #3053.
Update #3585.
Update #3285.
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* console/console.c: Include <rtems/termiostypes.h>.
Add missing prototype.
* console/console.c: Reflect termios_baud_to_number having been
renamed to rtems_termios_baud_to_number.
* console/console.c, include/m340timer.h, timer/timer.c: Eliminate
empty function from every benchmark timer driver. Fix spelling.
* console/console.c, include/m340timer.h, timer/timer.c: Rename timer
driver methods to follow RTEMS programming conventions.
* console/console.c, include/m340uart.h: Use new shared
termios_baud_to_number() routine.
* console/console.c: Remove warnings.
* clock/ckinit.c, console/Modif_cpu_asm.S, console/console.c,
console/m340uart.c, include/bsp.h, include/m340timer.h,
include/m340uart.h, start/start.S, start/startfor340only.S,
startup/bspclean.c, startup/bspstart.c, startup/dumpanic.c,
timer/timer.c: URL for license changed.
* console/console.c, console/m340uart.c: Removed warnings.
Here's a small patch I forgot about from earlier in the week that removes
the hack fix Geoffroy had to use to get his BSP to work properly.
The termios osend() fix took care of this.
and eliminate warnings.
Geoffroy Montel <g_montel@yahoo.com>.
