Updates #3053.
Update #3285.
* mcf5225x/network/fec.c, mcf5235/cache/cachepd.c,
mcf532x/cache/cachepd.c, shared/cache/cache.c, shared/misc/m68kidle.c:
* shared/misc/m68kidle.c: somehow this change was never committed, sorry.
* shared/misc/m68kidle.c: Change prototype of IDLE thread to
consistently return void * and take a uintptr_t argument.
* shared/misc/m68kidle.c: Correct prototype of Idle threads.
* shared/misc/m68kidle.c: URL for license changed.
* configure.ac, shared/misc/Makefile.am: PR217 required that the
idle task be moved to libcpu so it could be more acutely aware of
the CPU model. This file was modified to pick up the idle task
from there.
* shared/misc/m68kidle.c: New file.
