Update #3706.
replace.
searching and sorting.
Update #3706.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
do
echo $b
# echo $g
-i $b
done
Add doxygen to the header files in the m68k/cdb360 directory.
* include/bsp.h, startup/init5272.c:
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, include/bsp.h: Review of all bsp_cleanup()
implementations. In this phase, all prototypes were removed from
bsp.h and empty implementations were removed and made to use the
shared stub.
* startup/bspclean.c: Removed.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* console/console-io.c, include/bsp.h, start/start.S,
startup/bspclean.c, startup/bspstart.c, startup/init5272.c: Correct
license URL and/or fix mistake in copyright notice. Both of these
mistakes appear to be from code submitted after these changes were
made previously.
PR 1227/bsps
* include/bsp.h: Remove MAX_LONG_TEST_DURATION and
MAX_SHORT_TEST_DURATION. They are obsolete and unused.
* include/bsp.h: New header guard.
* include/bsp.h: Correct type of symbols from linkcmds to compile with
gcc 4.x.
* include/bsp.h, network/network.c, startup/bspstart.c,
startup/init5272.c: Use POSIX fixed-size types.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
times, console/.cvsignore, console/console-io.c, include/.cvsignore,
include/bsp.h, include/coverhd.h, include/tm27.h, network/network.c,
start/.cvsignore, start/start.S, startup/.cvsignore,
startup/bspclean.c, startup/bspstart.c, startup/init5272.c,
startup/linkcmds: New files.
