This patch changes the license to BSD-2 for all source files where the
copyright is held by Aeroflex Gaisler, Cobham Gaisler, or Gaisler Research.
Some files also includes copyright right statements from OAR and/or
embedded Brains in addition to Gaisler.
Updates #3053.
Update #3706.
Update #3678.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Some bugfixes at the same time. After this patch the drivers
may be used on RASTA systems having a big-endian PCI layout.
Removed not up to date changelogs, rely on git log instead.
Add doxygen to the header files in sparc/shared/include directory.
The drivers are updated to use the new AMBA layer, however the
backwards-compatibility interface (ambapp_old) is used.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
* Makefile.am, shared/can/occan.c, shared/include/ambapp.h: Add initial
i2c and update OC-CAN support.
* shared/i2c/i2cmst.c, shared/include/i2cmst.h: New files.
