path: root/bsps/include/grlib/gr_rasta_tmtc.h (unfollow)
2022-11-14bsps/include/grlib: Change license to BSD-2 for files with Gaisler copyrightDaniel Cederman1-3/+22
This patch changes the license to BSD-2 for all source files where the copyright is held by Aeroflex Gaisler, Cobham Gaisler, or Gaisler Research. Some files also includes copyright right statements from OAR and/or embedded Brains in addition to Gaisler. Updates #3053.
2019-01-22grlib: Move header filesSebastian Huber1-0/+0
Update #3678.
2018-01-25Remove make preinstallChris Johns1-0/+0
2015-04-17sparc bsps: updated license to rtems.orgDaniel Hellstrom1-1/+1
2015-04-17GR-RASTA-TMTC: fix build warningsDaniel Hellstrom1-2/+6
2015-04-17LEON: updated and added PCI peripherals for LEON BSPsDaniel Hellstrom1-0/+99
The CCHIP driver is replaced with the GR_701 driver. The RASTA driver is replaced by the GR-RASTA-IO driver. All drivers are now compatible with both LEON2 and LEON3, drivers were initialized directly by the PCI-board drivers are now initialized by the driver manager and therefore does not require the double code created by including for example grcan.c into grcan_rasta.c. The other drivers needs to be updated to the driver manager framework however. Added support for: * GR-701 (only LEON2 before) * GR-RASTA-IO (only LEON2 before) * GR-RASTA-ADCDAC * GR-RASTA-TMTC * GR-RASTA-SPW-ROUTER * GR-TMTC-1553
