Make the GIC interrupt controller support a subgroup of the generic interrupt
controller support.
brains GmbH.
Updates #3053.
Updates #4625.
This breaks out AArch32-specific code so that the shared GICv3 code can
be reused by other architectures.
This adds support for the GICv3 interrupt controller along with the
redistributor to control SGIs and PPIs which wasn't present in GICv2
implementations. GICv3 implementations only optionally support
memory-mapped GICC interface interaction and require system register
access be implemented, so the GICC interface is accessed only
through system registers.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
