Move _CPU_Fatal_halt() declaration to <rtems/score/cpuimpl.h> and make sure it
is a proper declaration of a function which does not return. Fix the type of
the error code. If necessary, add the implementation to cpu.c. Implementing
_CPU_Fatal_halt() as a function makes it possible to wrap this function for
example to fully test _Terminate().
Closes #4455
Update #3866.
Update #3850
Change license to BSD-2-Clause according to file histories and
re-licensing agreement.
Update #3899.
This fixes an issue with the latest tool chain which adds the default
linker script in the endfile specification.
Update #3250.
Closes #4093.
Update #3818.
- properly use the cpu <-> apic maps for IPIs
Closes #4029.
- Fixes timeout for smpipi01 where:
+ Main thread sends perform jobs to worker cpu while it is already
performing jobs
+ Interrupt on worker cpu performs jobs, but with empty job list
+ Worker cpu continues to execut previous job and adds new job list
to itself, which is never performed, since the interrupt has already
been handled
+ Main thread blocks forever on barrier D
- Do not forward Clock_isr through Clock_driver_support_at_tick as this
will cause every processor to send IPIs with Clock_isr therby creating
an infinie loop
- Instead the processor handling the clock interrupt causes all other
processors to call rtems_timecounter_tick to update their tick count
Create a GS segment in the GDT for each processor for storing TLS.
This makes the GDT in startAP.S obsolete as all processors now share the
same GDT, which is passed to each AP at startup.
The correct segment for each processor is calculated in cpu_asm.S.
Update #3335
start16.S is now only used for SMP configurations to start the
application processors.
This commit removes all unnecessary parts for this job,
i.e. video conssole initalisation, A20 gate activation
and all non-AP related code.
Update #3335
Add a simplified path evaluation function IMFS_eval_path_devfs() for a
device only IMFS configuration.
The code size can be further reduced by the application if it disables
the support for legacy IO drivers via:
#define CONFIGURE_IMFS_DISABLE_MKNOD
#define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
Obsolete CONFIGURE_MAXIMUM_DEVICES. Remove BSP_MAXIMUM_DEVICES.
Update #3894.
Update #3898.
The work area initialization was done by the BSP through
bsp_work_area_initialize(). This approach predated the system
initialization through the system initialization linker set. The
workspace and C program heap were unconditionally initialized. The aim
is to support RTEMS application configurations which do not need the
workspace and C program heap. In these configurations, the workspace
and C prgram heap should not get initialized.
Change all bsp_work_area_initialize() to implement _Memory_Get()
instead. Move the dirty memory, sbrk(), per-CPU data, workspace, and
malloc() heap initialization into separate system initialization steps.
This makes it also easier to test the individual initialization steps.
This change adds a dependency to _Heap_Extend() to all BSPs. This
dependency will be removed in a follow up change.
Update #3838.
Use _SMP_Multicast_action() instead.
Update #3706.
Update #3706.
replace.
searching and sorting.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
Update #3459.
Add and use <machine/rtems-bsd-kernel-space.h> and
<machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command
line defines and defines scattered throught the code base.
Simplify cpukit/libnetworking/Makefile.am.
Update #3375.
Pass current processor control as first parameter to make dependency
more explicit.
Pass current processor control via parameter since it may be already
available at the caller side.
Use a dedicated memory region or place it between the BSS and workspace.
Update #3459.
The aim of this clock driver hook was to stop clock tick interrupts at
some late point in the exit() procedure.
The use of atexit() pulls in malloc() which pulls in errno. It is
incompatible with the intention of the
CONFIGURE_DISABLE_NEWLIB_REENTRANCY configuration option.
The exit() function must be called from thread context, so accompanied
clock tick interrupts should cause no harm. On the contrary, someone
may assume a normal operating system operation, e.g. working timeouts.
Remove the Clock_driver_support_shutdown_hardware() clock driver hook.
Close #3436.
Update #3408.
Close #3410.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Closes #3349.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
