path: root/bsps/i386/include (follow)
* Remove explicit file names from @fileSebastian Huber2019-02-282-2/+2
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Remove make preinstallChris Johns2018-01-2511-0/+1097
