Update #3706.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
PR 1802
* shared/irq/irq_asm.S, shared/irq/irq_init.c, shared/smp/smp-imps.c,
shared/smp/smp-imps.h: Add SMP support for i386.
* shared/smp/getcpuid.c: New file.
* shared/irq/apic.h, shared/smp/smp-imps.c, shared/smp/smp-imps.h:
Reformat to be more compliant with RTEMS style.
* shared/irq/apic.h, shared/smp/smp-imps.c, shared/smp/smp-imps.h: Per
email with Erich Boleyn, change license to BSD style.
* shared/irq/apic.h, shared/smp/README, shared/smp/smp-imps.c,
shared/smp/smp-imps.h: New files.
