path: root/bsps/headers.am (follow)
* bsps/powerpc, bsps/shared: Move remaining legacy networking header filesVijay Kumar Banerjee2021-06-231-3/+0
* Makefile.am: Remove legacy networking filesVijay Kumar Banerjee2021-04-261-8/+0
* bsps/xilinx_zynq: Add Xilinx AXI SPI driver to autotools buildJan Sommer2021-03-301-0/+2
| | | | Closes #4321
* leon,can: introduce common CAN baud-rate calculation functionDaniel Hellstrom2021-03-111-0/+1
| | | | | | | Reimplemented the baud-rate algorithm from scratch to cope with GRCAN, GRCANFD and OC_CAN devices. Update #4323.
* bsps/xilinx_zynq: Add SPI driver to autotools buildJan Sommer2021-03-101-0/+5
| | | | Closes #4320
* Update header.amSebastian Huber2020-12-231-0/+4
* bsps: Move zynq-uart to bsps/sharedKinsey Moore2020-12-021-0/+2
| | | | | This moves the zynq-uart driver from bsps/arm/shared to bsps/shared to accomodate use by AArch64 BSPs.
* bsps: Break out AArch32 GICv3 supportKinsey Moore2020-10-051-0/+7
| | | | | This breaks out AArch32-specific code so that the shared GICv3 code can be reused by other architectures.
* Move ARM PL011 UART driverKinsey Moore2020-10-051-0/+5
| | | | This UART driver is now needed for BSPs other than ARM.
* bsps: Regenerate headers.amSebastian Huber2019-07-051-0/+1
| | | | Update #3269.
* bsps: Move VME header filesSebastian Huber2019-03-051-3/+0
| | | | They are only used by PowerPC BSPs.
* grlib: Move header filesSebastian Huber2019-01-221-0/+64
| | | | Update #3678.
* bsps/arm: Move bsp_memory_management_initialize()Sebastian Huber2018-04-241-1/+0
| | | | | | | | This function is only used by the raspberrypi BSP. This patch is a part of the BSP source reorganization. Update #3285.
* bsps: Move VME support to bspsSebastian Huber2018-04-091-5/+0
| | | | | | | | The VME support is only used by powerpc BSPs. This patch is a part of the BSP source reorganization. Update #3285.
* Remove make preinstallChris Johns2018-01-251-0/+83
