path: root/bsps/bfin/include/bf52x.h (unfollow)
2019-02-28Remove explicit file names from @fileSebastian Huber1-1/+1
This makes the @file documentation independent of the actual file name. Update #3707.
2018-01-25Remove make preinstallChris Johns1-0/+0
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-2/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2011-04-202011-04-20 Rohan Kangralkar <rkangral@ece.neu.edu>Joel Sherrill1-35/+30
PR 1781/bsps * bf52x/include: Added additional MMR. * bf52x/interrupt: The BF52X processors have a different System interrupt controller than present in the 53X range of processors. The 52X have 8 interrupt assignment registers. The implementation uses tables to increase predictability. * serial/uart.?: Added DMA based and interrupt based transfer support. The uart code used a single ISR for TX and RX and tried to identify and multiplex inside the ISR. In the new code the type of interrupt is identified by the central ISR dispatcher bf52x/interrupt or interrupt/. This simplifies the UART ISR.
2008-09-252008-09-25 Allan Hessenflow <allanh@kallisti.com>Joel Sherrill1-0/+2
* clock/clock.c, include/bf533.h, include/bf537.h, include/sicRegs.h:
2008-08-152008-08-15 Allan Hessenflow <allanh@kallisti.com>Joel Sherrill1-0/+136
* ChangeLog, Makefile.am, README, configure.ac, preinstall.am, cache/cache.c, cache/cache_.h, clock/clock.c, clock/rtc.c, clock/tod.h, include/bf533.h, include/bf537.h, include/cecRegs.h, include/coreTimerRegs.h, include/dmaRegs.h, include/ebiuRegs.h, include/ethernetRegs.h, include/gpioRegs.h, include/memoryRegs.h, include/mmuRegs.h, include/ppiRegs.h, include/rtcRegs.h, include/sicRegs.h, include/spiRegs.h, include/sportRegs.h, include/timerRegs.h, include/twiRegs.h, include/uartRegs.h, include/wdogRegs.h, interrupt/interrupt.c, interrupt/interrupt.h, mmu/mmu.c, mmu/mmu.h, network/ethernet.c, network/ethernet.h, serial/spi.c, serial/spi.h, serial/sport.c, serial/sport.h, serial/twi.c, serial/twi.h, serial/uart.c, serial/uart.h, timer/timer.c: New files.
